To generate App Builder code from the command line, run dtcodegen. Usage is described below.
Usage: dtcodegen [options] [project-file] [module-file [module-file] ...]
Code is generated for each module specified on the command line, or for all modules in the project, if no modules are specified. If no project file is specified, a project file containing the specified module(s) is searched for in the current directory.
Files with extension .bip are assumed to be BIL project files, files with .bix extension are assumed to be encapsulated BIL files, and files with a .bil extension are assumed to be BIL module files.
(* = default, + = default with no project file)
Print out this help message
Write file containing main()
Only generate files that have changed
Merge generated _stubs.c files with previous version
Don't merge existing and new stubs file
Specify a project to generate code for
Use default project settings, ignore project file
Application shows (maps) all windows at startup
Application shows (maps) only initially-visible windows
Silent mode, no messages written
Verbose mode, detailed progress messages
