The Revolving Property Editor is a single dialog box that displays one of 20 property editors, depending on the item you choose from the Object Type option menu. To display a separate, fixed property editor of a specific object type:
Select the object you want to edit in the interface or in the Module Browser. See "Module Browser" for a description of the Browser.
Choose Props from the pop-up menu (displayed by pressing mouse button 3 in the interface or in the Module Browser) and select Fixed from the Props submenu.
A fixed version of the property editor for the selected object type will be displayed.
Or
