Used to attach objects to each other for layout purposes, the Attachments Editor is described below.
An option menu for choosing the type of object for which you want to make attachments. Some object types (custom dialog, file selection dialog, main window) do not have parents and are not included in the menu.
A scrolling list for selecting the object for which you want to make attachments.
A text field that indicates the parent of the selected object.
A scrolling list that lists the children of the Parent object.
Radio buttons for displaying the attachments of the parent of the selected object or the attachments of the children of the selected object.
Some objects (draw area pane, term pane, text pane) cannot have children and may be children of a main window or custom dialog; thus, neither Parent attachments nor Attachments in child will be active. If the pane is a child of another pane, though, or if it is part of a layered pane, Parent attachments will be active.
Option menus for choosing the type of attachment for the selected object and what to attach the object to. Also includes text fields for specifying the Offset (in pixels) from the selected object and its parent or sibling (a sibling is another object with the same parent) or for specifying the Percentage offset of the selected object from its parent.
The option menu below "Attach To:" is for choosing which sibling to attach to and is active only for sibling attachments (two small squares). The Offset text field is active for absolute (pixel) attachments only; the Percentage text field is active for percentage attachments only.
The selected object is shown in the center of its four possible attachments. The attachments, starting at the top and going clockwise, are top edge of selected object, right edge of selected object, bottom edge of selected object, and left edge of selected object.
Top- and left-edge attachments are illustrated and described below; by default an object is attached at its top and left edges to the top and left edges of its parent. The selected object (the object at the center of the four Attach To boxes) is the controlling object: if you move this controlling object, the pixel or percentage offset is changed; click Reset to see current values after moving an attached object.
If an attached parent object is resized, its child objects will retain their pixel or percentage offsets from the edges of their parent. The offsets will change if a child object is moved.
Sibling icons (two small squares) are inactive if the selected object has no siblings.
An ascending line from the top edge of a small square to the top edge of its
surrounding box represents an absolute (pixel offset) attachment of the top
edge of the selected object to the top edge of its parent.
A descending line from the top edge of a small square to the bottom edge
of its surrounding box represents an absolute (pixel offset) attachment of
the top edge of the selected object to the bottom edge of its parent. This
value will be negative, since y values are positive as they ascend and negative
as they descend.
Two vertically-aligned squares connected by a vertical line represent an absolute
(pixel offset) attachment of the top edge of the selected object to the bottom
edge of its sibling. The offset will change if the selected object is moved.
This value will be negative if the top edge of the selected object is above
the bottom edge of its sibling.
Two horizontally-aligned squares connected by a horizontal line to the centers
of their top edges represent an absolute (pixel offset) attachment of the
vertical center of the selected object to the vertical center of its sibling.
The offset will change if the selected object is moved. This value will be
negative if the center of the selected object is above the center of its
sibling.
A square with a two-headed arrow and a percentage sign above it represents
a percentage offset attachment of the top edge of the selected object to
the top edge of its parent. The offset will change if the selected object
is moved.
A square with a percentage sign above it and a two-headed arrow between the
center line of the square and the top of the surrounding box represents a
percentage offset attachment of the center of the selected object to the
top edge of its parent. The offset will change if the selected object is
moved.
A circle with a diagonal line through it represents no attachment from the
edge (top, left, bottom, or right) to another object. By default a dropped
object has no right or bottom edge attachments.
Descriptions of the attachments to the bottom edge of the selected object are correlatives of the descriptions of the top-edge attachments above. Substitute "bottom" for "top" and "top" for "bottom" for bottom-edge attachments. Normally you will want top- and left-edge attachments only.
A horizontal line from the left edge of the surrounding box to the left edge
of a small square represents an absolute (pixel offset) attachment of the
left edge of the selected object to the left edge of its parent. The offset
A horizontal line from the right edge of the surrounding box to the left edge
left edge of the selected object to the right edge of its parent. The offset
will change if the selected object is moved. This value will be negative,
since x values are positive to the left and negative to the right.
Two horizontally-aligned squares connected by a horizontal line represent
an absolute (pixel offset) attachment of the left edge of the selected object
to the right edge of its sibling. The offset will change if the selected
object is moved. This value will be negative if the left edge of the selected
object is left of the right edge of its sibling.
Two vertically-aligned squares connected by a vertical line to the centers
of their left edges represent an absolute (pixel offset) attachment of the
horizontal center of the selected object to the horizontal center of its
sibling. The offset will change if the selected object is moved. This icon
is inactive if the selected object has no siblings. This value will be negative
if the center of the selected object is left of the center of its sibling.
a percentage offset attachment of the left edge of the selected object to
the left edge of its parent. The offset will change if the selected object
is moved.
A square with a percentage sign to its left and a two-headed arrow between
the center line of the square and the left of the surrounding box represents
a percentage offset attachment of the center of the selected object to the
left edge of its parent. The offset will change if the selected object is
moved.
Descriptions of the attachments to the right edge of the selected object are correlatives of the descriptions of the left-edge attachments above. Substitute "right" for "left" and "left" for "right" for right-edge attachments. Normally you will want top- and left-edge attachments only.
