The following program segment is part of a HelpRequestCB() function. Presumably, the USING_HELP constant is passed to the function because the user chose Using Help from the application's Help menu or chose the Help button in a quick help dialog.
This example assumes that the application never creates more than one Help On Help dialog and maintains its widget ID in a variable called onHelpDialog.
case USING_HELP:
if (onHelpDialog == (Widget)NULL)
/* Get a quick help dialog for use as the ` help on help' dialog. */
onHelpDialog = FetchHelpDialog (True);
/* We didn't get a dialog! Add your error handling code here. */
/* Set the proper volume and ID to display the home topic of
the help on help volume. Also, set the dialog's title. */
ac = 0; XtSetArg (al[ac], XmNtitle, "Help On Help"); ac++;
XtSetArg (al[ac], XmNhelpType, DT_HELP_TYPE_TOPIC); ac++;
XtSetArg (al[ac], XmNhelpVolume, "Help4Help"); ac++;
XtSetArg (al[ac], XmNlocationId, "_hometopic"); ac++;
XtSetValues (onHelpDialog, al, ac);
/* If the ` help on help' dialog is already managed, it might
be in another workspace, so unmanage it. */
if (XtIsManaged (onHelpDialog))
XtUnmanageChild (onHelpDialog);
/* Manage the ` help on help' dialog. */
XtManageChild (onHelpDialog);
break;
To see how the rest of the HelpRequestCB() function might be structured, refer to the example in "To Add a Help Callback".
