Defined term: Identifies a term and the term's definition within the glossary.
<glossary>
<dterm>first term
definition of first term
<dterm>Nth term
definition of Nth term
This element is used within the <glossary> section.
The name of the term follows the <dterm> tag and appears on the same line. The term's definition begins on the line following the <dterm> tag.
An end tag is not required.
The following markup defines the first two words in a glossary:
<glossary> <dterm>algorithm A mathematical rule or procedure for solving a problem. <dterm>click To press and release a mouse button.
