Common Desktop Environment: Help System Author's and Programmer's Guide
<var>
Variable: Indicates a user-supplied variable in a command.
Syntax
<var>
text
 <\var>
Or:
%%text%%
The <\var> end tag is required if the long form is used.
The shorthand form uses two %% (percent signs) before and after the text.
Example
These markups:
INPUT <var>filename<\var>
Or:
INPUT %%filename%%
produce:
INPUT filename
See Also
