Application help volume: The root structural element. This element contains all the markup for an entire help volume.
all entity declarations
<helpvolume>
all of your help is included here, either
literally or using file entity references
<\helpvolume>
If you do not enter this tag, its presence is automatically assumed by the HelpTag software.
All entity declarations must appear before the <helpvolume> start tag.
