Common Desktop Environment: Help System Author's and Programmer's Guide
File Entity Declarations
To declare a file entity in formal markup, use this syntax:
<!entity entityname SYSTEM "filename">
Where entityname is the name of the entity and filename is the name of the file. The keyword SYSTEM is required.
Note -
To use entity declarations previously created for shorthand markup, you must replace the FILE parameter with SYSTEM.
Example
Here are the entity declarations for a help volume that consists of three text files and contains a graphic image.
<!entity MetaInformation SYSTEM "metainfo>"
<!entity BasicTasks SYSTEM "basics">
<!entity AdvancedFeatures SYSTEM "advanced">
<!entity process_diagram SYSTEM "process.tif">
Entities are referenced in formal markup exactly as they are in shorthand markup.
