Common Desktop Environment: Help System Author's and Programmer's Guide
Examples
If your glossary has a definition for the term "widget", you can enter it as a term like this:
A ++widget++ is the fundamental building block of OSF/Motif user interfaces.
If the glossary entry is "widget", but you need to use the plural form within the sentence, you could enter the term like this:
<term  "widget">Widgets<\term> are the fundamental building blocks
If you want to enter the same term, but you either don't want to include it in the glossary or you don't want it to be a hyperlink, use the nogloss parameter like this:
<term nogloss> Widgets<\term>are the fundamental building blocks
The equivalent short form is:
<term nogloss|Widgets| are the fundamental building blocks
