Use the <link> element as shown:
<link manpage Man>text<\link>
To request a man page from a particular section, use the hyperlink parameter like this:
<link hyperlink="section manpage" Man>text<\link>
For man page links, the hyperlink parameter is the same string you would enter if executing the man command in a terminal emulator window.
If you are writing help for an application and you include any man page links, your application must include special support for man pages. See "To Display a Man Page". (The desktop Help Viewer includes support for man page links.)
The following is a link that displays the man page for the grep command:
Refer to the <link grep Man> grep(1)<\link> command.
The word Man in the example is a keyword for the <link> element, so if you want to create a link that displays the man page for the man command, you must use the hyperlink parameter:
Refer to the <link hyperlink="man" Man>man(1)<\link> command.
To display a man page in a particular section, precede the man page name with the section number. The following link displays the "mkdir" man page from section 2 (which is different from the man page of the same name in section 1):
Refer to the <link hyperlink= "2 mkdir" Man>mkdir(2)<\link> command.
