You can make searches more precise by tagging the string with indicators for the following characteristics:
Beginning of line
End of line
Beginning of word
End of word
Wildcard characters
To match the beginning of a line, start the search string with a caret (^). For example, to find the next line beginning with “Search”, type:
/^Search |
To match the end of a line, end the search string with a dollar sign ($). For example, to find the next line ending with “search.”, type:
/search\.$ |
Note that the period is escaped with a backslash.
To match the beginning of a word, type \< at the beginning of the string; to match the end of a word, type \> at the end of the string. Thus, to match a word, rather than a string, combine the end-of-word and beginning-of-word tags in the search pattern. For example, to find the next occurrence of the word—as opposed to the string—“search”, type:
/\<search\> |
To match any character, type a period (.) in the string at the location to be matched. For example, to find the next occurrence of “disinformation” or “misinformation,” type:
/.isinformation |
Because this is a search for a string and not a word, this search pattern might also find such constructions as “misinformationalist” and “disinformationism.”
To search for alternative characters in a string, enclose the alternatives in brackets. The search pattern /[md]stringfinds strings that begin with either “m” or “d.” Conversely, /[d-m]string finds strings that begin with any letter from “d” through “m.”
To match zero or more occurrences of the last character, type an asterisk (*) in the string. You can effectively combine brackets and the asterisk to look for well-defined alternatives. For example, to find all strings beginning with a through z and ending with “isinformation” and to find all occurrences of the string “isinformation”, type:
/[a-z]*isinformation |
