Why provide an assertion facility at all, given that one can program assertions atop the Java programming language with no special support?
Although ad hoc implementations are possible, they are of necessity either ugly (requiring an if statement for each assertion) or inefficient (evaluating the condition even if assertions are disabled). Further, each ad hoc implementation has its own means of enabling and disabling assertions, which lessens the utility of these implementations, especially for debugging in the field. As a result of these shortcomings, assertions have never become a part of the Java culture. Adding assertion support to the platform stands a good chance of rectifying this situation.
Why does this facility justify a language change, as opposed to a library solution?
We recognize that a language change is a serious effort, not to be undertaken lightly. The library approach was considered. It was, however, deemed essential that the runtime cost of assertions be negligible if they are disabled. In order to achieve this with a library, the programmer is forced to hard-code each assertion as an if statement. Many programmers would not do this. Either they would omit the if statement and performance would suffer, or they would ignore the facility entirely. Note also that assertions were contained in James Gosling's original specification for Java. Assertions were removed from the Oak specification because time constraints prevented a satisfactory design and implementation.
Why not provide a full-fledged design-by-contract facility with preconditions, postconditions and class invariants, like the one in the Eiffel programming language?
We considered providing such a facility, but were unable to convince ourselves that it is possible to graft it onto the Java programming language without massive changes to the Java platform libraries, and massive inconsistencies between old and new libraries. Further, we were not convinced that such a facility would preserve the simplicity that is Java's hallmark. On balance, we came to the conclusion that a simple boolean assertion facility was a fairly straight-forward solution and far less risky. It's worth noting that adding a boolean assertion facility to the language doesn't preclude adding a full-fledged design-by-contract facility at some time in the future.
The simple assertion facility does enable a limited form of design-by-contract style programming. The assert statement is appropriate for postcondition and class invariant checking. Precondition checking should still be performed by checks inside methods that result in particular, documented exceptions, such as IllegalArgumentException and IllegalStateException.
In addition to boolean assertions, why not provide an assert-like construct to suppress the execution of an entire block of code if assertions are disabled?
Providing such a construct would encourage programmers to put complex assertions inline, when they are better relegated to separate methods.
