This section briefly describes the widgets that are exclusive to OLIT.
This primitive widget implements both the source and destination ends of drag-and-drop operations.
These special widgets manage any number of subobjects within the context of a single widget. When implementing menus or choice objects that contain many subitems, they provide a significant memory savings.
This manager widget automatically supports a window with a floating footer area.
This manager widget allows relative-sizing constraints to be placed on its children.
This primitive widget enables you to customize its behavior without subclassing.
