The XView toolkit and the Xt (OLIT and Motif) toolkits use the following terminology:
XView |
Xt (OLIT and Motif) |
Package |
Widget |
Attribute |
Resources |
Frame |
Shell |
XView is based directly on Xlib, whereas Motif is based on the Intrinsics (Xt) toolkit and the Intrinsics toolkit is based on Xlib.
XView |
OLIT |
Motif |
XLib |
Xt |
Xt |
XLib |
XLib |
Because of this fundamental difference, the basic library functions to initialize the environment and create, modify and destroy graphical objects, are different, as shown in the following examples:
XView |
Motif/Xt |
xv_init() |
XtAppInitialize() |
xv_create() |
XtCreateWidget() |
xv_set() |
XtSetValues() |
xv_destroy() |
XtDestroyWidget() |
Functions that deal with event handling callbacks, and internationalization features, for example, get more complicated. For these features, simple one-to-one correspondence does not exist.
