Both XView and Motif are user interface toolkits that support some common types of user interface objects. However, XView implements many of these objects at a higher level that requires more than one Motif widget to produce the equivalent of a single XView object.
Table 5-3 lists the basic mapping of common objects for XView and its equivalent Solaris Motif widget:
Table 5-3 Basic Mapping of Common Objects.|
Equivalent Solaris Motif Widget |
Base Frame |
XmTopLevelShell + XmMainWindow |
Command Frame |
XmDialogShell + XmBulletinBoard |
Notice |
XmDialogShell + XmMessageBox (MessageDialog) |
Canvas |
XmScrolledWindow + XmDrawingArea |
Panel |
XmBulletinBoard or XmForm |
Panel Button |
XmPushButton |
Menu Button |
DtMenuButton (not accessible in OpenWindows environment) |
Abbrev Menu Button |
XmRowColumn (Option Menu) |
Checkbox |
XmRowColumn + XmToggleButtons (CheckBox) |
Exclusive Choice |
XmRowColumn + XmToggleButtons (Radio Box) |
Scrolling List |
XmScrolledWindow + XmList |
Message |
XmLabel |
Slider |
XmScale |
Text Field |
XmTextField |
Numeric Text Field |
DtSpinBox (not accessible in OpenWindows environment) |
Text SubWindow |
XmScrolledWindow + XmText (ScrolledText) |
TTY SubWindow |
XmScrolledWindow + XmTermPane; DtTerm (not accessible in OpenWindows environment) |
Scrollbar |
XmScrollBar |
Popup Menu |
XmMenuShell + XmRowColumn (Popup Menu) |
Pulldown Menu |
XmMenuShell + XmRowColumn (Pulldown Menu) |
Pullright Menu |
File Chooser |
XmDialogShell + XmFileSelectionBox |
