The Solaris X Window System Developer's Guide provides detailed information on the SolarisTM X server. The guide provides an overview of the server architecture and tells you where to look for more information.
This guide provides detailed information for software developers interested in interfacing with the Solaris X server.
Programming in this environment primarily involves using a toolkit and possibly interfacing with the server and its protocols. The protocols and toolkits are documented elsewhere, see Related Books. Read this manual if you need detailed information on the:
Features of the Solaris X server
Differences from and enhancements to the X Consortium sample server
DPS imaging system
Supported display devices
Authorization schemes and protocols for server connections
This manual assumes that the reader has a programming background and familiarity with, or access to, appropriate documentation for:
Solaris 7 and compatible versions
X Window SystemTM
C programming language
PostScriptTM
The Display PostScriptTM System (DPS)
olwm window manager
XViewTM toolkit
Although you can read this book in sequence, it is designed for you to read only those chapters of interest. This book serves both as an overview and as a reference document.
Chapter 1, Introduction to the Solaris X Server describes the architecture of the Solaris X server, the X and DPS extensions, Sun's enhancements to the X Consortium libraries and extensions, notes on color-related issues, and a list of applications you can run with the server.
Chapter 2, DPS Features and Enhancements describes the DPS features specific to Solaris and includes information on compositing operators provided as an extension to standard DPS.
Chapter 3, Visuals on the Solaris X Server describes visuals in the Solaris environment. It also provides hints for window programming with visuals.
Chapter 4, Font Support describes the set of fonts provided and how to manage fonts.
Chapter 5, Server Overlay Windows describes server overlays and contrasts them with transparent overlays.
Chapter 6, Transparent Overlay Windows describes the Solaris Transparent Overlay Extension application programming interface (API) for transparent overlay windows.
Chapter 7, Security Issues describes the security features of the Solaris environment.
Appendix A, Reference Display Devices describes the graphics devices provided as reference devices with the Solaris environment.
For information on how to write applications in the Solaris environment, consult the following manuals:
Desktop Integration Guide
ToolTalk Reference Guide
OpenWindows Desktop Reference Manual
Solaris X Window System Reference Manual
X Server Device Developer's Guide
XView Developer's Notes
OLIT Quick Start Programer's Guide
OLIT Reference Guide
The following X-related manuals are available through SunExpress or your local bookstore. Contact your Sun Microsystems representative for information on ordering any of these books.
XView Reference Manual, O'Reilly & Associates
XView Programming Manual, O'Reilly & Associates
Xlib Reference Manual, O'Reilly & Associates
Xlib Programming Manual, O'Reilly & Associates
X Protocol Reference Manual, O'Reilly & Associates
Programmer's Supplement for Release 5, O'Reilly & Associates
X Toolkit Intrinsics Reference Manual, O'Reilly & Associates
X Window System, Third Edition, Digital Press
The X Window System Server, X Version 11, Release 5, Digital Press
The following PostScript and DPS-related manuals are available through SunExpress or your local bookstore. Contact your Sun Microsystems representative for information on ordering.
PostScript Language Reference Manual, Second Edition, Adobe® Systems Incorporated
PostScript Language Tutorial and Cookbook, Adobe Systems Incorporated
Programming the Display PostScript System with X, Adobe Systems Incorporated
PostScript Language Program Design, Adobe Systems Incorporated
Adobe Type I Font Format, Adobe Systems Incorporated
In this document the term “IA” refers to the Intel 32–bit processor architecture, which includes the Pentium, Pentium Pro, Pentium II, Pentium II Xeon, Celeron, Pentium III, and Pentium III Xeon processors and compatible microprocessor chips made by AMD and Cyrix.
The docs.sun.comSM Web site enables you to access Sun technical documentation online. You can browse the docs.sun.com archive or search for a specific book title or subject. The URL is http://docs.sun.com.
The following table describes the typographic changes used in this book.
Table P–1 Typographic Conventions|
Typeface or Symbol |
Meaning |
Example |
AaBbCc123 | The names of commands, files, and directories; on-screen computer output |
Edit your .login file. Use ls -a to list all files. machine_name% you have mail. |
AaBbCc123 | What you type, contrasted with on-screen computer output |
machine_name% su Password: |
AaBbCc123 | Command-line placeholder: replace with a real name or value |
To delete a file, type rm filename. |
AaBbCc123 |
Book titles, new words, or terms, or words to be emphasized. |
Read Chapter 6 in User's Guide. These are called class options. You must be root to do this. |
The following table shows the default system prompt and superuser prompt for the C shell, Bourne shell, and Korn shell.
Table P–2 Shell Prompts|
Shell |
Prompt |
| C shell prompt | machine_name% |
| C shell superuser prompt | machine_name# |
| Bourne shell and Korn shell prompt | $ |
| Bourne shell and Korn shell superuser prompt | # |
