Table 1–1 lists the X11 libraries. The .so and .a files that comprise these
libraries are in /usr/openwin/lib.
Table 1–1 X11 Libraries| Library | Description | Available From the X Consortium | Sun Value Added |
libX11 |
Xlib |
Yes |
MT safe Dynamic loading of locale Search path includes /usr/openwin, New keysyms |
libXau |
X Authorization library |
Yes |
None |
libXaw |
Athena Widget Set library |
Yes |
None |
libXext |
X Extensions library |
Yes |
Bug fixes, transparent overlays |
libXinput |
Binary compatibility library for previous input extension |
No |
Sun library |
libXi |
Xinput Extension library |
Yes |
Bug fixes Supports Solaris X extensions |
libXmu |
X Miscellaneous Utilities library |
Yes |
Search path includes/usr/openwin |
libXol |
OLIT library |
No |
Sun product—see the preface for a list of OLIT manuals (Available from USL) |
libXt |
Xt Intrinsics library |
Yes |
None |
libxview |
XView library |
Yes |
Sun product donated to X Consortium Bug fixes not included in X11R6 libxview |
