With the default_charset string literal, any characters can be set as a valid string literal. For example, if the LANG environment variable is el_GR, the string literal with default_charset can contain any Greek character. If the LANG environment variable is ja_JP, the default_charset string literal can contain any Japanese character encoded in Japanese EUC.
If no character set is set to a string literal, the character set of the string literal is set as cur_charset. And, in the system environment, the cur_charset value is always set as default_charset.
Figure 4-4 shows a UIL sample program on English and Japanese environments.
In the following sample program, LLL indicates locale text, which can be Japanese, Korean, Traditional Chinese, Greek, French, or others.
uil_sample.uil
! sample uil file - uil_sample.uil
! C source file - uil_sample.c
! Resource file - uil-sample.resource
module Test
version = 'v1.0'
names = case_sensitive
objects = {
XmPushButton = gadget;
! declare callback procedure
procedure
exit_CB ;
! declare BulletinBoard as parent of PushButton and Text
object
bb : XmBulletinBoard {
arguments{
XmNwidth = 500;
XmNheight = 200;
controls{
XmPushButton
pb1;
XmText
text1;
! declare PushButton
object
pb1 : XmPushButton {
arguments{
XmNlabelString = #Normal "LLLexit buttonLLL";
XmNx = 50;
XmNy = 50;
callbacks{
XmNactivateCallback = procedure exit_CB;
! declare Text
text1 : XmText {
arguments{
XmNx = 50;
XmNy = 150;
end module;
* C source file - uil_sample.c
#include <Mrm/MrmAppl.h>
#include <locale.h>
void exit_CB();
static MrmHierarchy hierarchy;
static MrmType *class;
/* specify the UID hierarchy list */
static char *aray_file[]=
{"uil_sample.uid"
static int num_file = (sizeof aray_file / sizeof
aray_file[0]);
/* define the mapping between UIL procedure names */
/* and their addresses */
static MRMRegisterArg reglist[]={
{"exit_CB",(caddr_t) exit_CB}
