Common Desktop Environment: Internationalization Programmer's Guide
Setting a Compound String Programmatically
An application can set this resource programmatically by creating the compound string using the XmStringCreateLocalized() compound string convenience function.
This function creates a compound string in the encoding of the current locale and automatically sets the font list entry tag to XmFONTLIST_DEFAULT_TAG.
The following code segment shows one way to set the XmNlabelString resource for a push button using a program.
#include <nl_types.h>
Widget		button;
Args		args[10];
int		n;
 XmString button_label;
nl_msg my_catd;
(void)XtSetLanguageProc(NULL,NULL,NULL);
button_label = XmStringCreateLocalized (catgets(my_catd, 1, 1,
  		 	"default label"),
  			XmFONTLIST_DEFAULT_TAG);
/* Create an argument list for the button */
n = 0;
XtSetArg (args[n], XmNlabelString, button_label); n++;
/* Create and manage the button */
button = XmCreatePushButton (toplevel, "button", args, n);
XtManageChild (button);
XmStringFree (button_label);
