This chapter explains how to install fonts, modify the font path, and use the directory chooser.
Choose Install from the Fonts menu.
At the top of the Install dialog, click the List Fonts From Directory button.
Use the directory chooser to browse for and select the directory containing the fonts you want to install. When you find the directory you want, double-click the directory, and then click Choose to display a list of fonts in the directory. For more information about the directory chooser, see To Use the Directory Chooser.
There may be a pause while Font Administrator searches for fonts in the directory you choose.
On the Install dialog, select the font or fonts you want to install. If you want to install all the fonts, click Select All.
Choose the local host or a printer for which to install fonts.
Use the directory chooser to browse for and select the installation destination directory. For more information about the directory chooser, see To Use the Directory Chooser.
Check that the disk space available is greater than the disk space required.
Click Install.
To install fonts to the shared system directory /usr/openwin, you must run Font Administrator as the root user.
If there is a conflict between a font you tried to install, and a font with the same name that has already been installed, Font Administrator displays the conflict dialog.
The conflict dialog lists the fonts you tried to install that already exist on your system.
To keep all of the previously installed fonts, click Save.
To replace all fonts:
Click Replace All.
Click Save.
To replace selected fonts:
Click a font you want to replace.
Click Replace.
Repeat steps 1 and 2 for each font you want to replace.
When you have completed steps 1 and 2 for each font you want to replace, click Save.
When you, as the root user, install a font into a directory that is not in the default font path, Font Administrator offers to add it to the default font path for you automatically. You can also choose to add it manually by using the Modify Font Path dialog.
This dialog only appears if you run Font Administrator as the root user. For other users, Font Administrator appends the installation directory to the user's font path. The change to the user's font path lasts until the user quits Font Administrator.
To modify the font path, you must run Font Administrator as the root user.
Modifying the font path may include the following subtasks:
To list the font path
To reorder the font path
To delete font path Elements
To add font path Elements
The default font path is shared. Modifying the default font path will affect all users who reference it.
Installing OpenWindows will initialize the default font path. You may want to keep a record of the changes you make to the default font path, so that you can recreate them if you install OpenWindows.
To list the font path you want to modify:
Choose Modify Font Path from the Options menu.
On the Modify Font Path dialog, click the appropriate radio button for the font path you want to modify.
If you are modifying the font path for another OpenWindows installation on the local host, click Directory and use the directory chooser to select the alternative OpenWindows installation. For more information about the directory chooser, see To Use the Directory Chooser.
If you are modifying the font path for a NeWSprint printer, select the printer on the printer option menu.
Font Administrator lists the font path you choose.
To reorder the font path:
On the Modify Font Path dialog, Figure 3–3, list the font path to modify.
Click the font path element you want to move.
Click Move Up or Move Down to place the font path element where you want it.
Repeat steps 3 and 4 until the font path elements are in the order you want.
Click OK or Apply to apply the changes.
To delete font path elements:
Click the font path element you want to delete.
Click Delete.
Repeat steps 3 and 4 until you have deleted the elements you want to delete.
To add font path elements:
Click in the New Font Path Element text box.
Either type the new font path element, or click Directory to use the directory chooser to browse for and select the directory that you want to add to the font path. When you find the directory you want, double-click the directory, and then click Choose to enter the directory in the New Font Path Element text box. For more information about the directory chooser, see To Use the Directory Chooser.
On the Modify Font Path dialog, Figure 3–3, click Add New.
Repeat steps 3 to 5 until you have added the font path elements you want to add.
Choose the directory containing fonts to install.
Choose the destination directory for font installation.
Choose the directory containing the OpenWindows installation for which you want to modify the font path.
Choose the directory to add to the font path.
The title bar indicates the current reason for displaying the directory chooser.
The directory chooser consists of the following parts:
Type and/or view the path to go to. To choose a directory from a diskette or CDROM, click the option arrow and select the desired type of drive.
Display only those files and folders that match.
When you go to a directory, lists its subdirectories.
When you go to a directory, lists its files.
Choose the last directory for which you did a Go To.
Display a list of folders and files for the directory named at the top of the directory chooser.
If you click a folder but do not click Go To, the folder name appears at the top of the directory chooser but the parent directory is still selected. To avoid choosing the parent directory by accident, always double-click or Go To the folder you want.
The Files list is always grayed out, because the task is to choose a directory (a folder), not a file.
