Font Administrator User's Guide
To List the Font Path
    To list the font path you want to modify:
  1. Choose Modify Font Path from the Options menu.
  2. On the Modify Font Path dialog, click the appropriate radio button for the font path you want to modify.
  3. If you are modifying the font path for another OpenWindows installation on the local host, click Directory and use the directory chooser to select the alternative OpenWindows installation. For more information about the directory chooser, see To Use the Directory Chooser.
  4. If you are modifying the font path for a NeWSprint printer, select the printer on the printer option menu.
Font Administrator lists the font path you choose.
