y
n/a
n
Required
_
_
_
4-29:
When the keyboard focus
policy is explicit, the destination component is the editable component that
last had the keyboard focus. When the keyboard focus policy is implicit, the
destination component is the editable component that last received mouse button
or keyboard input.
The destination component is used to identify
the component on which certain operations, primarily data transfer operations,
act. There is only one destination component at a time.
Required
_
_
_
4-30:
If the keyboard focus is
in a component (or a pop-up menu of a component) that supports selections,
operations that act on a selection act on the selection in that component.
A selection operation acts on the component that has focus, if
that component supports selections.
Required
_
_
_
4-31:
in a component (or a pop-up menu of a component) that supports some operation
that does not act on a selection, invoking the operation acts on that component.
An operation that does not act on a selection acts on the component
that has focus, if that component supports the operation.
Required
_
_
_
4-32:
Inserting or pasting elements
into a selection, except for a primary transfer operation at the bounds of
the primary selection, first deletes the selection if pending delete is enabled.
Pending delete controls the conditions under which the selection
is deleted. It is enabled by default.
Required
_
_
_
4-33:
In normal mode, inserting
or pasting elements disjoint from the selection also deselects the selection,
except for primary transfer operations whose source and destination are in
the same collection. In add mode, the selection is not deselected.
In add mode, a transfer operation that is disjoint from the selection does
not affect the selection.
Required
_
_
_
4-34:
In editable list-like and
graphics-like collections, Delete deletes the selected elements.
Delete provides a consistent means of deleting the selection.
Required
_
_
_
4-35:
In editable text-like collections,
Delete and Backspace behave as follows:
If the selection is not empty and the control is in normal
mode, the selection is deleted.
If the selection is not empty, the control is in add mode,
and the cursor is not disjoint from the selection, the selection is deleted.
If the selection is not empty and the control is in add mode,
but the cursor is disjoint from the selection, Delete deletes one character
forward, and Backspace deletes one character backward.
If the selection is empty, Delete deletes one character forward,
In text, Delete and Backspace provide a convenient way
to delete the entire selection or single characters.
