y |
n/a |
n |
Optional |
_ |
_ |
_ |
ah: |
Applications should provide unique window icons for their primary windows. The window icon image should have a similar appearance to the associated file or Front Panel icon image. |
Optional |
_ |
_ |
_ |
ai: |
The window icon label should contain the same text as the title of the corresponding primary window, or an abbreviated form of it. Refer to "Layout" for window title guidelines. |
Optional |
_ |
_ |
_ |
aj: |
The window icon image should have a similar appearance to the associated file or Front Panel icon image. Refer to "Design Philosophy and Helpful Hints". |
