y |
n/a |
n |
Required |
_ |
_ |
_ |
hw: |
Present the items as a ring of items that wrap. For example, if a user is at the largest number and presses the up arrow, the smallest number is displayed and vice versa so that the user can spin through all the items by pressing the same arrow. |
Required |
_ |
_ |
_ |
hx: |
Move through the items in a spin box as shown in Table 10-5. |
Table 10-5 Navigation in a Spin Box
Movement |
Keys |
Example |
Toward the beginning of the list |
left arrow, down arrow |
Chronological: If Tuesday is displayed, move to Monday when the user presses the left or down arrow. Magnitude: If 15 is displayed, move to 14 when the user presses the left or down arrow. |
Toward the end of the list |
right arrow, up arrow |
Chronological: If Tuesday is displayed, move to Wednesday when the user presses the right or up arrow. Magnitude: If 15 is displayed, move to 16 when the user presses the right or up arrow. |
y |
n/a |
n |
Recommended |
_ |
_ |
_ |
hy: |
Values can be set using the arrow buttons or through keyboard input. Values should be evaluated immediately upon entry. If a value is entered that is already in the list, scroll to the position of that entry in the list. |
Recommended |
_ |
_ |
_ |
hz: |
If entry of non-listed items is permitted, use the following behavior. When a new value is entered, scroll the list to the position appropriate for the new entry. If the user scrolls off the new entry, scroll to the next appropriate value in the list and the keyboard-entered value is lost. |
Recommended |
_ |
_ |
_ |
ia: |
On entry of an invalid value, an auditory warning and error message should be provided. |
