Recommended
bv:
If
your application includes a Help menu, it contains the following set of choices,
with the specified functionality, when the actions are actually supported
by your application. The Help choices included here supersede those listed
for Motif 1.2.
This is the Common Desktop Environment-recommended
Help menu and should be used instead of the Motif 1.2 Help menu. Items should
be presented to the user in the order listed.
Overview [REQUIRED]
Provides general information about the window from which help was accessed
or about the application overall. The mnemonic is v. Place a separator after.
Index [OPTIONAL]
Provides an index listing topics for all help information available
for your application. The mnemonic is I.
Table of Contents [RECOMMENDED]
Provides a table of contents listing topics for all help information
available for your application. The mnemonic is C.
Tasks [RECOMMENDED]
Provides access to help information indicating how to perform different
tasks using your application. The mnemonic is T.
Reference [RECOMMENDED]
Provides access to reference information. The mnemonic is R.
Tutorial [OPTIONAL]
Provides access to your application's tutorial. The mnemonic is l.
Keyboard [OPTIONAL]
Provides information about your application's use of function keys,
mnemonics, and keyboard accelerators. Also provides information on general
Common Desktop Environment use of such keys. The mnemonic is K.
Mouse [OPTIONAL]
Provides information about using a mouse with your application. The
mnemonic is M.
Mouse and Keyboard [OPTIONAL]
mnemonics, keyboard accelerators and mouse operations. Also provides information
on general Common Desktop Environment use of such keys. The mnemonic is M.
On Item [OPTIONAL]
Initiates context-sensitive help by changing the shape of the pointer
to the question mark pointer. When the user moves the pointer to a component
and presses BSelect, any available context-sensitive help for the component
is presented. The mnemonic is O.
Using Help [REQUIRED]
Provides information on how to use the Common Desktop Environment Help
Facility. The mnemonic is U.
About applicationname [REQUIRED]
Displays a dialog box indicating, minimally, the name and version of
your application, and displaying its icon or some other signature graphic
for your application. The mnemonic is A.
The Overview, Using Help and About items are required.
The Table of Contents, Tasks and Reference items are recommended. You can
choose to have separate Mouse and Keyboard topics, or have a single combined
Mouse and Keyboard topic. You should not use all three items.
