Recommended
by:
Your
application should provide a pop-up menu for any element that is selectable
within its data pane.
Recommended
bx:
If
your application provides functions that apply to a data pane and not any
specific element therein, then a pop-up menu is provided that contains the
frequently used data pane functions and is accessible by pressing BMenu when
the mouse pointer is over the background of the pane or a nonselectable element
within the pane.
Recommended
cb:
The
functions accessible from within your application's pop-up menus are also
accessible from buttons displayed within the window or menus accessed through
the menu bar.
Recommended
ca:
Every
pop-up menu in your application has a title that indicates the function the
menu performs or the element on which it operates.
Optional
cd:
Choices within your
pop-up menus are organized in the following manner:
<choices
that manage the object such as Open, Save, and Properties>
separator ----------------
<standard edit menu choices such
as Cut, Copy and Paste>
----------- separator ----------------
<other choices>
Optional
6-11:
If your application
uses any of the common pop-up menu actions, the actions function according
to the following specifications. See item for supplemental guidelines.
Properties
Displays a properties dialog box that the user can use to set the properties
of the component.
Undo
Reverses the last executed action.
Primary Move
Moves the contents of the primary selection to the component. This action
is available only in editable components.
Primary Copy
Copies the contents of the primary selection to the component. This
action is available only in editable components.
Primary Link
Places a link to the primary selection in the component. This action
Cut
Cuts elements to the clipboard. If the menu is popped up in a selection,
cuts the entire selection to the clipboard.
Copy
Copies elements to the clipboard. If the menu is popped up in a selection,
copies the entire selection to the clipboard.
Copy Link
Copies a link of elements to the clipboard. If the menu is popped up
in a selection, copies a link to the entire selection to the clipboard.
Paste
Pastes the contents of the clipboard to the component. This action is
Paste Link
Pastes a link of the contents of the clipboard to the component. This
Clear
Removes a selected portion of data from the client area without copying
it to the clipboard. If the menu is popped up in a selection, deletes the
selection.
Delete
selection.
Select All
Sets the primary selection to be all of the elements in the collection
with the pop-up menu.
Deselect All
Deselects the current selection in the collection with the pop-up menu.
Select Pasted
Sets the primary selection to be the last element or elements pasted
into the collection with the pop-up menu.
Reselect
Sets the primary selection to be the last selected element or elements
in the component with the pop-up menu. This action is available only in components
that do not support persistent selections and only when the current selection
is empty.
Promote
Promotes the current selection to the primary selection. It is available
only in components that support persistent selections.
Recommended
cc:
Pop-up
menus for selectable objects contain the following set of choices, with the
specified functionality, when the actions are actually supported by your application.
These guidelines supplement item .
Move To...
Allows the user to move the selected objects into a folder. A file selection
dialog box is displayed allowing the user to select the desired folder.
Copy To...
Allows the user to copy the selected objects into a folder. A file selection
Put in Workspace
Allows the user to put a link for the selected objects onto the Common
Desktop Environment desktop in the current workspace.
Delete
Deletes the selected object. A confirmation is displayed to the user
before actually removing the object.
Help...
Displays a help window pertaining to objects of the type selected.
Required
6-12:
When a pop-up menu
is popped up in the context of a selection, any action that acts on elements
acts on the entire selection.
In the context of a selection, pop-up
menu actions affect the entire selection.
