Required |
fd: |
If you use a tool bar, it should be used only in windows with a menu bar. |
Required |
fe: |
Tool bars should contain only operations that are already available to the user in your application menus. All items in a tool bar should be redundant. Items in a toolbar are meant to provide quick access to operations that are already accessible to the user by other methods. |
Required |
ff: |
When an action represented by a tool bar icon is unavailable to the user, that icon should be made insensitive, with the associated stippled appearance. Whenever a menu item is made insensitive, the corresponding tool bar item must be made insensitive as well. |
Recommended |
fg: |
Give users the option to hide the tool bar. |
