Optional |
hu: |
Labels should be clear. In the English language, use the following labels for the file selection dialog box fields and lists: |
Component |
Label |
Directory text field |
Enter Path or Folder Name |
Filter text Field |
Filter |
Directory list |
Folder |
Contents list |
Files |
File text field |
Enter Filename:* |
Optional |
hv: |
Optionally, application developers can make this label more instructive and specific, such as Enter File to Open for Open dialog boxes. (see following sections for specific recommendations). These labels should be the default labels. If they are not set by default, you need to set them via resources in your application's app-defaults file. |
Recommended |
he: |
When the file selection box is used to specify an existing file (for example, to open a document), the command button is normally labeled Open and it should be the default action. |
Required |
hj: |
When the file selection dialog box is used to specify a new file name (for example, a Save As dialog box), the command button is normally labeled Save and is the default action. This specification ensures the uniform appearance of a file selection box across applications. |
