This section contains instructions on how to use the GB2312 codes to type Chinese characters and symbols.
In a new Terminal, turn Chinese input conversion on by pressing Control-spacebar.
Click the Input method selection button on the auxiliary window and select GB2312 input method.
The status area shows that GB2312 code input mode is on.
Press the first three of the four keys that represent the character to display (in this example, b0a1).
The key remains visible in the preedit area.
Type the fourth key.
The character automatically replaces the preedit area.
