This section contains instructions on how to use the GBK codes to type Chinese characters and symbols.
In a new Terminal, turn Chinese input conversion on by pressing Control-spacebar.
Press F4 to turn on the GBK code input method.
The status area shows that GBK code input mode is on.
Press the first three of the four keys that represent the character to display (in this example, b0a1).
The key remains visible in the preedit area.
Type the fourth key.
The character automatically replaces the preedit area.
