To add a Hanja word to the Hangul-Hanja dictionary proceed as follows:
Click on the Add button of the main screen to bring up the Add/Modify dialog box:
Type a new word or change the existing word in the Add/Modify dialog box, and commit (Control-K) the Hangul word to associate with the Hanja word you wish to add to your dictionary.
In the Hanja field, type the Hanja word associated with the Hangul word you wish to add to your dictionary.
Use the (character-by-character) methods described in "Converting to Hanja" on page 22.
Click on the Add button.
A display like the following appears:
The line beneath the status area tells you the word was added to the User Dictionary. (Only the User Dictionary is changed; the System Dictionary is read-only).
