Installing Solstice Enterprise Agents (SEA) on the Solaris operating system follows Standard Solaris conventions, as described in the following sections.
The SEA package is divided into two major parts:
SNMP
DMI
This product is supported on the following platforms:
Sparc (Solaris 2.4, 2.5, and 2.6)
IA (Solaris 2.4, 2.5, and 2.6)
The runtime product includes the following unique packages:
SUNWsacom
SUNWsasnm
SUNWsadmi
SUNWmibii
SUNWsasdk (optional package for agent development)
The following sections describe the details of each package.
The SUNWsacom package contains all the configuration files corresponding to the other three packages. The files in this package are installed in the /root and /var file systems. These files include configuration files and other common files.
The SUNWsasnm package includes:
snmpdx – Master Agent executable
init.snmpdx – Startup script file
snmpdx.mib – Master Agent MIB file
Libraries
Within SUNWsadmi, the package includes:
dmispd – DMI Service Provider (SP) executable
DMI libraries – See Table 2–3
snmpXdmid – DMI/SNMP mapper executable
init.dmi – Startup script file
ciinvoke – Script to invoke CI agents, from init.dmi
Script to invoke CI agents – Invoked by ciinvoke
dmi_cmd and dmiget – Command line MI utilities
The SUNWmibii package contains the mibiisa MIB II subagent. The subagent provides MIB II functionality. The functionality provided by MIB II subagent is the same as that provided by the snmpd agent released with Domain Manager.
This package contains SNMP Toolkit and the DMI Toolkit to build the subagents.
SNMP Toolkit contains:
mibcodegen
Header files
Standard MIB files
Sample MIB and Example Code
DMI Toolkit includes:
miftomib compiler
libdmi
libci
libmi
sp.mif
Sample files for CI and MI
Packages are installed using the pkgadd command and are removed by the pkgrm command.
The snmpXdmid must be configured properly in the Master Agent configuration files.
Before starting your installation procedure, be sure you log in as root. Then follow the procedures below.
If these packages don't exist, you don't have to remove them.
With the addition of each package, you receive both the English and French copyrights, then a series of prompts that you can either answer specifically or accept the default.
Add SUNWmibii:
pkgadd -d . SUNWmibii
Add SUNWsasnm:
pkgadd -d . SUNWsasnm
Add SUNWsadmi:
pkgadd -d . SUNWsadmi
Add SUNWsacom:
pkgadd -d . SUNWsacom
Add SUNWsasdk
pkgadd -d . SUNWsasdk
When you add the SUNWsadmi package, the dmispd and snmpXdmid processes start upon reboot of the system.
The SUNWsacom package consists of two script files; init.dmi and init.snmpdx. The SNMP daemon, snmpdx, is invoked by init.snmpdx. The snmpdx process automatically starts the mibiisa daemon.
The dmispd process is invoked through the RC script files when the system is booted, as is snmpdx. The snmpXdmid mapper process is invoked after the dmispd has been invoked.
When deleting or adding packages, be sure you follow the order described above.
Table 2–1 shows a list of default software locations within SNMP.
Table 2–1 Default SNMP Locations|
Label |
Directory |
SEA_SNMPLibrary_Directory |
/usr/lib |
SEA_SNMPConfiguration_Directory |
/etc/snmp/conf |
SEA_SNMPMibs_Directory |
/var/snmp/mib |
Table 2–2 provides the list of SNMP component names and their default locations.
Table 2–2 SNMP Package Components|
Component Name |
Label/Directory |
Description |
snmpdx |
/usr/lib/snmp |
Master Agent executable |
mibiisa |
/usr/lib/snmp |
MIB II snmp daemonpwd |
snmp_trapsend |
/usr/sbin |
Utility for sending traps |
mibcodegen |
/usr/bin |
Code generator executable |
snmpdx.rsrc |
Master Agent resource file |
snmpdx.reg |
Registration file for agents |
snmpdx.acl |
Master Agent access control file |
snmpd.conf |
SNMPD configuration file |
mibiisa.reg |
MIB II subagent registration file |
mibiisa.rsrc |
MIB II agent resource file |
snmpdx.st |
SEA_SNMPRun_Time_Directory |
Master Agent status file |
libssasnmp.so.1 |
SSA SDK SNMP library |
libssagent.so.1 |
SSA SDK Agent library |
enterprises.oid |
Default enterprise-name OID map |
sun.mib |
Sun MIB |
snmpdx.mib |
Snmpdx MIB |
Table 2–3 provides a list of default software locations for the DMI portion of the product.
Table 2–3 Default Locations for DMI|
Label |
Location |
SEA_DMILibrary_Directory |
/usr/lib |
SEA_DMIConfiguration_Directory |
/etc/dmi/conf |
SEA_DMIRunTime_Database_Directory |
/var/dmi/db |
SEA_DMIRunTime_MAP_Directory |
/var/dmi/map |
SEA_DMIMif_Directory |
/var/dmi/mif |
Table 2–4 provides a list of DMI component names and their default locations.
Table 2–4 DMI Package Components|
Component name |
Label/Directory |
Description |
snmpXdmid |
/usr/lib/dmi |
Mapper executable |
dmispd |
/usr/lib/dmi |
DMI Service Provider executable |
dmi_cmd |
/usr/sbin |
DMI command utility |
dmiget |
/usr/sbin |
snmpXdmid.conf |
Mapper configuration file |
dmispd.conf |
DMI SP configuration file |
map files |
Map files |
libdmi.so.1 |
SSA SDK DMI generic library |
libci.so.1 |
SSA SDK CI library |
libdmimi.so.1 |
SSA SDK MI library |
sp.mif |
MIF files |
ciinvoke |
/etc/dmi/ciagent |
DMI component interface invocation script |
