This utility translates DMI MIF files to SNMP format and generates a map configuration file. The Network Management application (Sun Net Manager, Enterprise Manager, etc.) may use the MIB to manage the DMI-based component MIF. The mapper process uses the map file. The map file helps in mapping SNMP-based MIB variables to the DMI-based MIF attributes.
miftomib ”[mifname=] [value value ...]” mifpathname [mibpathname]Table 5–2 MIF-to-MIB Compiler Arguments
Argument |
Definition |
mifname |
The name of the mib object generated |
value |
One or more integers separated by a space |
mifpathname |
The mif file |
mibpathname |
The mib file generated |
