This chapter provides an introduction to the Desktop Management Task Force (DMTF) special interest group, manageability, and the Desktop Management Interface (DMI).
The DMTF was formed in May of 1992 as a cooperative effort of eight companies: Digital Equipment CorporationTM, Hewlett-PackardTM, IBMTM, IntelTM, MicrosoftTM, NovellTM, SunTM, and SynOpticsTM. The objective of the DMTF was to provide a simple solution for desktop manageability.
The DTMF created a standard interface that handles communication between any management application and all the manageable products on -- or attached to -- a desktop PC or server.
This standard is called the DMI. For more information on the DMI, refer to the DMI Specification Version 2.0 at http://www.dmtf.org
The DMI is:
Independent of any specific operating system, hardware platform, or management protocol
Easy for vendors to adopt
Scalable, to accommodate a wide range of products from very simple to very complex and extensible
Mappable to existing management and remote protocols
DMI functionality for the SEA includes the following:
Dynamic installation and removal of component instrumentations and management application
Responsibility for all runtime access to the MIF data
Assurance that at least one group (the component ID group) is in each MIF file
Responsibility for launching the component instrumentation, if necessary
Slicing commands. When a management application requests more than one attribute value from a component in a single command, the SP sends commands to the component instrumentation for each attribute
Assurance that commands serialize to a component instrumentation and ensure that commands are allowed to run to completion. Multiple requests for a particular component instrumentation must be queued
Forward indications based on subscription and filters to each registered management application and timestamp incoming indications before forwarding them
Send indications to all registered management applications that subscribe to receive indications when components are installed or removed from the MIF database
Appear to management applications as a component with ID 1 (one). As a component, it must support the standard ComponentID group. Additionally, the DMI SP must support the subscription and filter standard group. Also, similar to a component, it may define additional groups beyond the ComponentID group
Customers may use the DMI-based solution included in the SEA product in several ways. For example, it may act as another SNMP subagent. Additionally, DMI-based management applications may be written to directly interact with SP.
In the SNMP subagent mode, the SNMP requests are mapped to DMI requests and are communicated with DMI SP. In the direct mode, the management applications may directly interact with the SP using DMI.
Figure 5–1 illustrates the overall architecture of how the DMI solution relates to the Enterprise Agents.
The DMI SP is the core of the DMI solution. Management applications and Component instrumentations communicate with each other through the SP. The SP coordinates and arbitrates requests from the management application to the specified component instrumentations. SP handles runtime management of the Component Interface (CI) and the Management Interface (MI), including component installation, registration at the MI and CI level, request serialization and synchronization, event handling for CI, and general flow control and housekeeping.
Figure 5–2 illustrates the elements that exist within a single system, or are directly attached. The management application may be used as a DMI browser.
The DMI SP consists of four modules:
MI (an interface used by the management application to communicate with DMI SP)
Component Interface (the SP interface for component instrumentation code use)
The MI functionality for the SEA includes the following:
A management application communicates with the DMI through the MI. A management application requests information about components in the system by issuing the DMI Get, Set, and List commands. It also registers with the SP for event notifications and proper filtering capabilities.
When an event is generated, the DMI SP looks into its subscription and filtering table. DMI SP forwards the event in case it passes through the filtering process. The event is then forwarded to all management applications that have subscribed with the SP to receive such events.
The components communicate with the DMI through the CI. The components' subagents are created by end users to manage the respective components (devices/applications, etc.). The following functions are provided by the CI:
Sending Events – Component instrumentation sends an indication block to the SP for processing. The DMI mapper translates the DMI indication an SNMP trap.
Components respond to the DMI SP requests to Get and Set various attributes instrumented by the component subagent.
The MIF database functionality for the SEA includes the following:
There is one MIF database associated with the SP. Each component has a MIF file to describe its manageable characteristics. When the component is initially installed into the system, the MIF is added to the MIF database. SP controls all access to the MIF database.
No MIF modification mechanism the to MIF database is provided. If the MIF needs to change, it must be uninstalled and modified using regular text editor tools, and then installed again.
Upon installation and removal of a MIF from the MIF database, the SP must issue an indication to all registered management applications.
After installing, a script file invokes the DMI SP at boot time if the /etc/dmi/conf/dmispd.conf configuration file contains neither blank lines nor comment lines. The DMI SP is invoked using the following options:
dmispd [-h] [-c config_dir] [-d debug_level]Table 5–1 Invoking DMI SP Arguments
Argument |
Definition |
-h |
Displays the command line usage |
-c confid_dir |
The full path of the directory containing the dmispd.conf configuration file |
-d debug_level |
In debug mode, the process does not run as a daemon and it displays trace messages on the display screen; depending on the debug_level (1-5), it prints a specific amount of information |
The DMI API library provided with the SEA package is a C library containing procedures for developing management applications using DMI. The library also provides a component interface for users to create subagents, including component instrumentation for the management of components. Additionally, DMI APIs simplify the processes of installing components in the MIF database and invoking the SP's component interface.
This utility translates DMI MIF files to SNMP format and generates a map configuration file. The Network Management application (Sun Net Manager, Enterprise Manager, etc.) may use the MIB to manage the DMI-based component MIF. The mapper process uses the map file. The map file helps in mapping SNMP-based MIB variables to the DMI-based MIF attributes.
miftomib ”[mifname=] [value value ...]” mifpathname [mibpathname]Table 5–2 MIF-to-MIB Compiler Arguments
Argument |
Definition |
mifname |
The name of the mib object generated |
value |
One or more integers separated by a space |
mifpathname |
The mif file |
mibpathname |
The mib file generated |
The mapper is an SNMP subagent acting as a DMI management application. It sends management requests to the DMI SP using the management interface. It also processes events from the component through the SP and passes them on to the Master Agent. Thus, the DMI-enabled component looks like any other SNMP-managed component. Figure 5–3 illustrates the mapper and component communication.
The following sections describe the subagent tasks during the life cycle.
Registers itself with SP, so the SP may provide services, such as access to the MIF database and indications from components.
Builds a translation table for mapping. This is done by reading the map files created for each component. The translation table is built when the mapper initially comes up. Later, when a new component is installed and registered with the SP, the DMI SP sends an event to the mapper. The mapper then adds the new map file entry into its mapping table.
Establishes a connection between the Master Agent and subagent; it also registers itself with the Master Agent.
Builds up the translation table used for SNMP/DMI mapping and translating SNMP OIDs to DMI objects dynamically.
The mapper is invoked using the following options:
snmpXdmid -s hostname [-h] [-c config_dir] [-d debug_level]Table 5–3 Invoking DMI SP Arguments
Argument |
Definition |
-h |
-s hostname |
The name of the host where the SP is running; by default it is the local host |
-c config_dir |
The full path of the directory containing the snmpXdmid.conf configuration file |
-d debug_level |
