After installing, a script file invokes the DMI SP at boot time if the /etc/dmi/conf/dmispd.conf configuration file contains neither blank lines nor comment lines. The DMI SP is invoked using the following options:
dmispd [-h] [-c config_dir] [-d debug_level]Table 5–1 Invoking DMI SP Arguments
Argument |
Definition |
-h |
Displays the command line usage |
-c confid_dir |
The full path of the directory containing the dmispd.conf configuration file |
-d debug_level |
In debug mode, the process does not run as a daemon and it displays trace messages on the display screen; depending on the debug_level (1-5), it prints a specific amount of information |
