The mapper is invoked using the following options:
snmpXdmid -s hostname [-h] [-c config_dir] [-d debug_level]Table 5–3 Invoking DMI SP Arguments
Argument |
Definition |
-h |
Displays the command line usage |
-s hostname |
The name of the host where the SP is running; by default it is the local host |
-c config_dir |
The full path of the directory containing the snmpXdmid.conf configuration file |
-d debug_level |
In debug mode, the process does not run as a daemon and it displays trace messages on the display screen; depending on the debug_level (1-5), it prints a specific amount of information |
