dmi_cmd [-s hostname] -h | -V | -W config | -X | -CI mif_filename | -CL [-c compId] [-r reqMode] [-d] [-p] [-m maxCount] | -CD -c compId | -GI schema_filename -c compId | -GL -c compId -g groupId [-r reqMode] [-d] [-p] [-m maxCount] | -GM -c compId [-m maxCount] | -GD -c compId -g groupId | -NI schema_filename -c compId | -NL -c compId | -ND -c compId -l language_string | -AL -c compId -g groupId [-a attrId] [-r reqMode] [-d] [-p] [-m maxCount]
The command line arguments for dmi_cmd are shown in Table 7–1.
Table 7–1 dmi_cmd Command Line Arguments|
Argument |
Description |
-s hostname |
Specifies the host machine that dmisp is running on; the default host is the local host |
-h |
Prints usage information |
-V |
Retrieves version information about the DMI SP |
-W config |
Sets the configuration specified in config to dmisp |
-X |
Retrieves configuration information describing the current language in use |
-CI mif_filename |
Installs the component specified in mif_filename |
Lists components |
-CD -c compId |
Deletes the component specified by compId |
Installs the group schema specified in schema_filename |
Lists the groups for a specified component |
Lists class names for a specified component |
Deletes specified groups for a specified component |
Installs the language schema specified in schema_filename |
-NL -c compId |
Lists language mappings for a specified component |
Deletes language mapping for a specified component |
-AL -c compId -g groupId [-a attrId] [-r reqMode] [-d] [-p] [-m maxCount] |
Lists attributes for a specified component |
The values for compId, groupId, attrId, and maxCount are positive integers. The default value is 0.
The valid integer values for reqMode are:
1 (DMI_UNIQUE)
2 (DMI_FIRST)
3 (DMI_NEXT)
The default value for reqMode is 1 (DMI_UNIQUE). If an invalid reqMode is specified, the default value is used.
When listing components (-CL), groups (-GL), or attributes (-AL), use the -d option to display descriptions and the -p option to display the pragma string.
The following command lists the component ID, name, and description of up to 5 components, starting from component 3 in the dmispd running on the host snowbell, by using the default request mode (DMI_UNIQUE).
%dmi_cmd -s snowbell -CL -d -c 3 -m 5 Connecting to dmispd on the snowbell... CompId: 4 Comp Name: DMTF Developers - Direct Interface Version Description: A list of the people who actually wrote the code. CompId: 5 Comp Name: DMTF Developers - Direct Interface Version Description: A list of the people who actually wrote the code. CompId: 6 Comp Name: DMTF Developers - Direct Interface Version Description: A list of the people who actually wrote the code. CompId: 7 Comp Name: DMTF Developers - Direct Interface Version Description: A list of the people who actually wrote the code. CompId: 8 Comp Name: DMTF Developers - Direct Interface Version Description: A list of the people who actually wrote the code.
The following command lists the ID, name, storage, access mode, date type, and maximum size of all attributes in group 1 of component 1 in the dmispd running on local host, by using default request mode (DMI_UNIQUE). No description is displayed, and no limitation is set for max count.
%dmi_cmd -AL -g 1 -c 1 Connecting to dmispd on the localhost... 12 attrs listed for group 1 of comp 1 Attr Id: 1 Name: Manufacturer Storage: MIF_COMMON Access: MIF_READ_ONLY Type: MIF_DISPLAYSTRING maxSize: 64 Attr Id: 2 Name: Product Storage: MIF_COMMON Access: MIF_READ_ONLY Type: MIF_DISPLAYSTRING maxSize: 64 Attr Id: 3 Name: Version Storage: MIF_COMMON Access: MIF_READ_ONLY Type: MIF_DISPLAYSTRING maxSize: 64 Attr Id: 4 Name: Serial Number Storage: MIF_SPECIFIC Access: MIF_READ_ONLY Type: MIF_DISPLAYSTRING maxSize: 64 Attr Id: 5 Name: Installation Storage: MIF_SPECIFIC Access: MIF_READ_ONLY Type: MIF_DATE maxSize: 0 Attr Id: 6 Name: Verify Storage: MIF_SPECIFIC Access: MIF_READ_ONLY Type: MIF_INTEGER maxSize: 0 Attr Id: 7 Name: ComponentId Storage: MIF_SPECIFIC Access: MIF_READ_ONLY Type: MIF_INTEGER maxSize: 0 Attr Id: 8 Name: ComponentName Storage: MIF_SPECIFIC Access: MIF_READ_ONLY Type: MIF_DISPLAYSTRING maxSize: 256 Attr Id: 9 Name: ComponentDesc Storage: MIF_SPECIFIC Access: MIF_READ_ONLY Type: MIF_DISPLAYSTRING maxSize: 256 Attr Id: 10 Name: GroupId Storage: MIF_SPECIFIC Access: MIF_READ_ONLY Type: MIF_INTEGER maxSize: 0 Attr Id: 11 Name: GroupName Storage: MIF_SPECIFIC Access: MIF_READ_ONLY Type: MIF_DISPLAYSTRING maxSize: 256 Attr Id: 12 Name: LanguageName Storage: MIF_SPECIFIC Access: MIF_READ_ONLY Type: MIF_DISPLAYSTRING maxSize: 256
The following command installs namedir.mif in dmispd running on localhost. The file namedir.mif is located in the directory specified in the configuration file.
%dmi_cmd -CI namedir.mif Connecting to dmispd on the localhost... "namedir.mif" is installed as comp 21.
The following command uninstalls component 5 in dmispd running on localhost.
%dmi_cmd -CD -c 5 Connecting to dmispd on the localhost... comp 5 is uninstalled.
The following command displays the version of dmispd running on the snowbell machine.
%dmi_cmd -s snowbell -V Connecting to dmispd on the snowbell... dmispd version: Dmi2.0 description: This is a DMI2.0 based on ONC RPC
