The first time a ToolTalk 1.1 and compatible versions, ttsession is started, the user type database is automatically converted from the CE database to the new ToolTalk Types database. However, you can manually convert the current user database with the command:
ttce2xdr [ -xnh ] -d user |
Table A–1 describes the options for the ttce2xdr script.
Table A–1 ttce2xdr Script Options|
Option |
Description |
-x |
Displays the underlying commands executed by ttce2xdr. |
-n |
Displays the underlying commands that ttce2xdr can execute. |
-h |
Describes the options for ttce2xdr. |
-d |
Specifies the database to be converted: user, system, or network. |
The types are read from the CE database
~/.cetables/cetables
and written to the new ToolTalk Types database
~/.tt/types.xdr
