A network CE database is the per-OW-installation database. You need to convert each network CE database that has ToolTalk types other than those shipped with the OpenWindows Version 3 product.
You must be logged in as root to run the ttce2xdr script for the network CE databases.
To convert a network-wide database, enter the following command on the command line:
ttce2xdr [ -xnh ] -d network [ OPENWINHOME-from [ OPENWINHOME-to ]] |
Table A–3 describes the options for the ttce2xdr script.
Table A–3 ttce2xdr Script Options|
Option |
Description |
-x |
Displays the underlying commands executed by ttce2xdr. |
-n |
Displays the underlying commands that ttce2xdr can execute. |
-h |
Describes the options for ttce2xdr. |
-d |
Specifies the database to be converted: user, system, or network. |
Reads the types from the databases under this
directory. If |
Writes the types to the databases under this
directory. If |
The types are read from the CE database
$OPENWINHOME/lib/cetables/cetables
and written to the new ToolTalk Types database
$OPENWINHOME/etc/tt/types.xdr
To move ToolTalk types other than the ones shipped with the OpenWindows Version 3 product from the network CE database to the network XDR database, enter the following command on the command line:
ttce2xdr -d network old_OPENWINHOME new_OPENWINHOME |
where old_OPENWINHOME is the OpenWindow installation that holds the old network CE database and new_OPENWINHOME is the OpenWindow installation in which to update the ToolTalk XDR database.
