The dynamic method provides message pattern information while your application is running. You create a message pattern and register it with the ToolTalk service. You can add callback routines to dynamic message patterns that the ToolTalk service will call when it matches a message to the pattern.
To create and register a dynamic message pattern, you allocate a new pattern object, fill in the proper information, and register it. When you are done with the pattern (that is, when you are no longer interested in messages that match it), either unregister or destroy the pattern. You can register and unregister dynamic message patterns as needed.
The ToolTalk functions used to create, register, and unregister dynamic message patterns are listed in Table 9–1.
Table 9–1 Functions for Creating, Updating, and Deleting Message Patterns|
ToolTalk Function |
Description |
tt_pattern_create(void) |
Create Pattern |
tt_pattern_arg_add(Tt_pattern p, Tt_mode n, const char *vtype, const char *value) |
Add string arguments |
tt_pattern_barg_add(Tt_pattern m, Tt_mode n, const char *vtype, const unsigned char *value, int len) |
Add byte array arguments |
tt_pattern_iarg_add(Tt_pattern m, Tt_mode n, const char *vtype, int value) |
Add integer arguments |
tt_pattern_xarg_add(Tt_pattern m, Tt_mode n, const char *vtype, xdrproc_t xdr_proc, void *value) |
Adds an xdr argument to a byte array |
tt_pattern_bcontext_add(Tt_pattern p, const char *slotname, const unsigned char *value, int length); |
Add byte array contexts |
tt_pattern_context_add(Tt_pattern p, const char *slotname, const char *value); |
Add string contexts |
tt_pattern_icontext_add(Tt_pattern p, const char *slotname, int value); |
Add integer contexts |
tt_pattern_address_add(Tt_pattern p, Tt_address d) |
Add address |
tt_pattern_callback_add(Tt_pattern p, Tt__message_callback_action f) |
Add message callback |
tt_pattern_category_set(Tt_pattern p, Tt_category c) |
Set category |
tt_pattern_class_add(Tt_pattern p, Tt_class c) |
Add class |
tt_pattern_disposition_add(Tt_pattern p, Tt_disposition r) |
Add disposition |
tt_pattern_file_add(Tt_pattern p, const char *file) |
Add file |
tt_pattern_object_add(Tt_pattern p, const char *objid) |
Add object |
tt_pattern_op_add(Tt_pattern p, const char *opname) |
Add operation |
tt_pattern_opnum_add(Tt_pattern p, int opnum) |
Add operation number |
tt_pattern_otype_add(Tt_pattern p, const char *otype) |
Add object type |
tt_pattern_scope_add(Tt_pattern p, Tt_scope s) |
Ad scope |
tt_pattern_sender_add(Tt_pattern p, const char *procid) |
Add sending process identifier |
tt_pattern_sender_ptype_add(Tt_pattern p, const char *ptid) |
Add sending process type |
tt_pattern_session_add(Tt_pattern p, const char *sessid) |
Add session identifier |
tt_pattern_state_add(Tt_pattern p, Tt_state s) |
Add state |
tt_pattern_user_set(Tt_pattern p, int key, void *v) |
Set user |
tt_pattern_register(Tt_pattern p) |
Register pattern |
tt_pattern_unregister(Tt_pattern p) |
Unregister pattern |
tt_pattern_destroy(Tt_pattern p) |
Destroy message pattern |
The return type for all functions except tt_pattern_create is Tt_status; tt_pattern_create returns Tt_pattern.
To create message patterns, use the tt_pattern_create function. You can use this function to get a handle or opaque pointer to a new pattern object, and then use this handle on succeeding calls to reference the pattern.
To fill in pattern information, use the tt_pattern_attribute_add and tt_pattern_attribute_set calls. You can supply multiple values for each attribute you add to a pattern. The pattern attribute matches a message attribute if any of the values in the pattern match the value in the message. If no value is specified for an attribute, the ToolTalk service assumes that you want any value to match. Some attributes are set and, therefore, can only have one value.
To add a callback routine to your pattern, use the tt_pattern_callback_add function.
Callbacks are called in reverse order of registration (for example, the most recently added callback is called first).
When the ToolTalk service matches a message, it automatically calls
your callback routine to examine the message and take appropriate actions.
When a message that matches a pattern with a callback is delivered to you,
it is processed through the callback routine. When the routine is finished,
it returns TT_CALLBACK_PROCESSED
and the API objects involved in the operation are freed. You can then use tt_message_destroy to destroy the message, which frees the storage
used by the message, as illustrated in the following code sample.
Tt_callback_action
sample_msg_callback(Tt_message m, Tt_pattern p)
... process the reply msg ...
tt_message_destroy(m);
return TT_CALLBACK_PROCESSED;
To register the completed pattern, use the tt_pattern_register() function. After you register your pattern, you join the sessions or files of interest.
The following code sample creates and registers a pattern.
If delivered messages that matched the deleted pattern have not been retrieved by your application (for example, the messages might be queued), the ToolTalk service does not destroy these messages.
To delete a message pattern, use the tt_pattern_destroy() function. This function first unregisters the pattern and then destroys the pattern object.
To stop receiving messages that match a message pattern without destroying the pattern object, use the tt_pattern_unregister() to unregister the pattern.
The ToolTalk service will automatically unregister and destroy all message pattern objects when you call tt_close.
To update your message patterns with the session or file in which you are currently interested, join the session or file.
When you join a session, the ToolTalk service updates your message pattern
with the sessid. For example, if you have declared a ptype or registered a
message pattern that specifies TT_SESSION
or TT_FILE_IN_SESSION, use tt_session_join to join the default session. The following code
sample shows how to join the default session.
/* * Join the default session */ tt_session_join(tt_default_session()); |
Table 9–2 lists the ToolTalk functions you use to join the session in which you are interested.
Table 9–2 ToolTalk Functions for Joining Default Sessions|
Return Type |
ToolTalk Function |
Description |
char * |
tt_default_session(void) |
Return default session id |
Tt_status |
tt_default_session_set(const char *sessid) |
Set default session |
char * |
tt_initial_session(void) |
Return initial session id |
Tt_status |
tt_session_join(const char *sessid) |
Join this session |
Tt_status |
tt_session_quit(const char *sessid) |
Quit session |
Once your patterns are updated, you will begin to receive messages scoped to the session you joined.
If you had previously joined a session and then registered a ptype or a new message pattern, you must again join the same session or a new session to update your pattern before you will receive messages that match your new pattern.
When you no longer want to receive messages that reference the default session, use the tt_session_quit() function. This function removes the sessid from your session-scoped message patterns.
When you join multiple sessions, you will automatically get responses to requests and point-to-point messages but you will not get notices unless you explicitly join the new session. The following code sample shows how to join the multiple sessions.
tt_default_session_set(new_session_identifier); tt_open(); tt_session_join(new_session); |
In order to effectively use multiple sessions, you must store the session
ids of the sessions in which you are interested in order to pass these identifiers
to tt_default_session_set prior to opening a new session
with tt_open; that is, you need to place the values (which ttsession stores in the environment variable _SUN_TT_SESSION) in a file on the system so that other ToolTalk
clients can access the value of a session id contained in that file and use
it to open the non-default session. For example, you can store the session
ids in a “well-known” file and then send a file-scoped message
(indicating this file) to all clients which have registered an appropriate
pattern. The client will then know to open the scoped-to file, read one or
more session ids from it, and use these session ids (with tt_open) to open a non-default session. An alternative method is advertising
the session ids by means of, for example, a name service or a third-party
database.
How ttsession session ids are stored and passed to interested clients is beyond the scope of the ToolTalk protocol and must be determined based on the architecture of the system.
When you join a file, the ToolTalk service automatically adds the name
of the file to your file-scoped message patterns. For example, if you have
declared a process type or registered a message pattern that specifies TT_FILE or TT_FILE_IN_SESSION, use the tt_file_join function()
to join files of interested. Table 9–3 lists the ToolTalk functions you use to express your interest in specific
files.
Return Type |
ToolTalk Function |
Description |
char * |
tt_default_file(void) |
Join default file |
Tt_status |
tt_default_file_set(const char *docid) |
Set default file |
Tt_status |
tt_file_join(const char *filepath) |
Join this file |
Tt_status |
tt_file_quit(const char *filepath) |
Quit file |
When you no longer want to receive messages that reference the file, use the tt_file_quit() function to remove the file name from your file-scoped message patterns.
