ttsession
Communicates with other ttsessions
on the network to deliver messages.
rpc.ttdbserverd
Stores and manages ToolTalk object
specs and information on files referenced in ToolTalk messages.
ttcp ttmv ttrm ttrmdir
tttar
These
commands are standard operating system shell commands that inform the ToolTalk
service when files that contain ToolTalk objects or files that are the subject
of ToolTalk messages are copied, moved, or removed.
ttdbck
A database check and recovery tool
for the ToolTalk databases.
tt_type_comp
This is a compiler for ptypes and otypes.
It compiles the ptype and otype files and automatically installs them in the
ToolTalk Types database.
ttce2xdr
Converts ToolTalk type data from the
Classing Engine database format to the XDR-database format.
ttsnoop
This is a Motif application that enables
you to register ToolTalk patterns and/or send ToolTalk messages, and to generally
observe ToolTalk message traffic. It is useful both for debugging existing
applications and as a tutor in understanding how different parts of a pattern
filter incoming messages.
tttrace
tttrace is analogous
to truss(1). It is an application that can be used in two
ways. It enables you to trace either the message-passing and pattern-matching
occurring in a given ttsession, or it can be used to provide
a per-program trace of all calls into the ToolTalk API.
libtt.so.2
This is the application programming
interface (API) library.
tttk.h and tt_c.h (located in /usr/dt/include/Tt)
Header files that contain the ToolTalk
functions used by applications to send and receive messages.
/usr/openwin/man/man1
ToolTalk
man pages for the user commands such as ttsession, ttdbck, tt_type_comp, and so on.
/usr/openwin/man/man1m
ToolTalk
man pages for the ToolTalk administrative commands suc such as rpc.ttdbserverd, ttdbck, and so on.
/usr/openwin/man/man3
ToolTalk
man pages for the ToolTalk API calls.
/usr/openwin/man/man4
ToolTalk
man pages for the ToolTalk message sets, and for configuration files used
for by ttsession(1) and rpc.ttdbserverd(1m)
/usr/openwin/man/man5
ToolTalk
man pages for the ToolTalk include files.
ttsample, edit_demo, and Makefile (located in /usr/openwin/share/src/tooltalk/demo)
Source code for simple ToolTalk demo programs.
