When you press the Messages button on the initial display window, the popup panel shown in Figure 5–2 is displayed.
Add Message
Press this button to store the current message settings. Once the messages are stored, you can recall and send these messages using the Send Message button on the initial display window.
Edit Contexts
Press this button to add, change, and delete send message contexts. The popup window displayed, shown in Figure 5–3, allows you to edit contexts to be sent with your messages.
Send Message
Press this button to send the newly created message.
This button performs the same function as the Send Message button on the main menu.
