Applications that want to receive ToolTalk messages provide information to the ToolTalk service that describes what kind of messages they want to receive. This information, known as message patterns, is provided dynamically either by applications as they run, or through ptype and otype files.
Installing application types is an occasional task; you only need to install type information when new types are created, or when an application error condition exists. Ptype and otype files are run through the ToolTalk type compiler at installation time. tt_type_comp merges the information into the ToolTalk Types Database. The application then tells the ToolTalk service to read the type information in the database.
To install an application's ptype and otype files, follow these steps:
Run tt_type_comp on your type file.
% tt_type_comp your-file |
tt_type_comp runs your-file through cpp, compiles the type definitions, and merges the information into a ToolTalk Types table. Table 5–1 describes location of the XDR-base format tables; Table 5–2 describes the location of the Classing Engine-base format table.
The Classing Engine interface exists for compatibility reasons only. The default is XDR.
Database |
Uses XDR Table |
user |
~/.tt/types.xdr |
system |
/etc/tt/types.xdr |
desktop |
/usr/dt/appconfig/tttypes/types.xdr |
network |
$OPENWINHOME/etc/tt/types.xdr |
Table 5–2 Classing Engine-base Format ToolTalk Types Tables
Database |
Uses Classing Engine Table |
user |
~/.cetables/cetables |
system |
/etc/cetables/cetables |
network |
$OPENWINHOME/lib/cetables/cetables |
There are four XDR databases. The $TTPATH environment variable determines which three will be used. See tt_type_comp(1) for details about the format and priority of $TTPATH entries.
By default, tt_type_comp uses the user database. To specify another database, use the -d option. For example:
% tt_type_comp -d user|system|[network|desktop]your_file |
When you run tt_type_comp on your ptype or otype files, it first runs cpp on the file and then checks the syntax before it places the data into the ToolTalk Types Database format. If syntax errors are found, a message is displayed that indicates the line number of the cpp file. To find the line, enter: cpp -P source-file temp-file and view the temp-file to find the error on the line reported by tt_type_comp.
ttsession will reread the ToolTalk Types Database automatically.
To force ttsession to reread the ToolTalk Types Database, see the Updating the ToolTalk Service.
You can examine all type information in a specified ToolTalk Types Database, only the ptype information, or only the otype information. To specify the database you want to examine, use the -d option and supply the name of the user, system, or network to indicate the desired database. If the -d option is not used, tt_type_comp will use the user database by default.
To examine all the ToolTalk type information in a ToolTalk Types Database, enter the following line
% tt_type_comp -d user|system|network -p |
The type information will be printed out in source format.
To list all ptypes in a ToolTalk Types Database, enter the following line:
% tt_type_comp -d user|system|network -P |
The names of the ptypes will be printed out in source format.
To list all otypes in a ToolTalk Types Database, enter the following line:
% tt_type_comp -d user|system|network -O |
The names of the otypes will be printed out in source format.
You can remove both ptype and otype information from the ToolTalk Types Databases.
Use tt_type_comp to remove type information. Enter the following line:
% tt_type_comp -d user|system|network -r type |
For example, to remove a ptype called EditDemo from the ToolTalk Types network database of a sample application, enter the line:
% tt_type_comp -d network -r EditDemo |
After you remove type information, force any running ttsessions to reread the ToolTalk Types Database again to bring the ToolTalk service up-to-date. See Updating the ToolTalk Service for more information.
When you make changes to the ToolTalk Types Database with tt_type_comp(1), the ToolTalk Service will automatically be notified to reread the types files. If you wish to explicitly force a ToolTalk session that is already running to reread the databases, send the ttsession process a SIGUSR2.
Enter the ps command to find the process identifier (pid) of the ttsession process
% ps -ef | grep ttsession |
Enter the kill command to send a SIGUSR2 signal to ttsession.
% kill -USR2 ttsession_pid |
One or both of the following conditions exists if applications report the error:
Application is not an installed ptype. |
The ToolTalk service has not been instructed by the application to reread the recently updated type information in the ToolTalk Types Database. See Updating the ToolTalk Service for instructions on how to force the ToolTalk service to reread type information from the ToolTalk Types Database.
The application's ptypes and otypes have not been compiled and merged into the ToolTalk Types Database. See Installing Application Types for instructions on how to compile and merge type information.
ttsnoop is a tool provided to create and send custom-constructed ToolTalk messages. You can also use ttsnoop as a tool to selectively monitor any or all ToolTalk messages. The ttsnoop program resides in the directory /usr/dt/bin/ttsnoop. To start the program, enter the following command on the command line:
% /usr/dt/bin/ttsnoop [ -t ] |
The -t option displays the ToolTalk API calls that are being used to construct a particular pattern or message. Figure 5–1 shows the window that is displayed when ttsnoop starts.
Start
Press this button to activate message reception. ttsnoop will display any incoming messages which match the patterns you register.
Stop
Press this button to stop receiving messages.
Clear
Press this button to clear the window.
About TTSnoop
Press this button to obtain general help for ttsnoop.
To obtain help for individual buttons and settings, place the
mouse over the button or setting and press the F1 key or Help key on your
keyboard. Your HELPPATH environment
variable must contain the directory that contains the TTSnoop .info files.
Display
Press this button to popup a panel of checkboxes to highlight specific ToolTalk message components on the ttsnoop display subwindow.
Messages
Press this button to popup a panel which enables you to create, store, and send ToolTalk messages.
Patterns
Press this button to popup a panel which allows you to compose and register ToolTalk patterns.
Send Messages
Press this button to send messages that were stored using the Messages popup.
When you press the Messages button on the initial display window, the popup panel shown in Figure 5–2 is displayed.
Add Message
Press this button to store the current message settings. Once the messages are stored, you can recall and send these messages using the Send Message button on the initial display window.
Edit Contexts
Press this button to add, change, and delete send message contexts. The popup window displayed, shown in Figure 5–3, allows you to edit contexts to be sent with your messages.
Send Message
Press this button to send the newly created message.
This button performs the same function as the Send Message button on the main menu.
When you press the Patterns button on the initial display window, the popup panel shown in Figure 5–4 is displayed.
Press the Apply button to register your pattern. Once a pattern is registered, you can use ttsnoop as a debugging tool to observe what messages are being sent by other applications.
Edit Receive Contexts
Press this button to add, change, and delete receive message contexts in patterns. The popup window displayed, shown in Figure 5–5, allows you to edit contexts to be registered with your patterns.
When you press the Display button on the initial display window, the popup panel of checkboxes shown in Figure 5–6 displays.
When you select a checkbox, the specified ToolTalk message component is indicated on a displayed message by an arrow (--->) to the left of the displayed message component. Figure 5–7 shows the displayed message components.
When you press the Send Message button on the initial display window, you can send one the messages you created and stored using the Messages popup.
When you press the Start button on the initial display window, ttsnoop will display any incoming messages which match the patterns you registered. Figure 5–8 is an example of a displayed incoming message.
When you press the Stop button on the initial display window, ttsnoop will stop receiving messages.
