The attributes in your message pattern specify the type of messages you want to receive. Although some attributes are set and have only one value, you can supply multiple values for most of the attributes you add to a pattern.
Table 3–1 provides a complete list of attributes you can put in your message patterns.
Table 3–1 ToolTalk Message Pattern Attributes|
Pattern Attribute |
Value |
Description |
Category |
Declares whether you want to perform the operation listed in a message or only observe a message. |
Scope |
Declares interest in messages about a session or a file, or both; Join a session or file after the message pattern is registered to update the sessid and filename. |
Arguments |
arguments or results |
Declares the positional arguments for the operation in which you are interested. |
Context |
<name, value> |
Declares the keyword or non-positional arguments for the operation in which you are interested |
Class |
Declares whether you want to receive notices, requests, offers, or all. |
File |
char *pathname |
Declares the files in which you are interested. If the scope of the pattern does not require a file, the file is an attribute only. |
Object |
char *objid |
Declares what objects in which you are interested. |
Operation |
char *opname |
Declares the operations in which you are interested. |
Otype |
char *otype |
Declares the type of objects in which you are interested. |
address |
Declares the type of address in which you are interested. |
disposition |
Instructs the ToolTalk service how to handle messages to your application if an instance is not currently running. |
sender |
char *procid |
Declares the sender in which you are interested. |
sender_ptype |
char *ptype |
Declares the type of sending process in which you are interested. |
session |
char *sessid |
Declares the session in which you are interested. |
state |
Declares the state of the message in which you are interested. |
All your message patterns must at least specify:
Category — Whether the application wants to perform operations listed in messages or only view messages.
Use TT_OBSERVE
if you only want to observe messages.
Use TT_HANDLE
if you want to perform operations requested by the messages.
Use TT_HANDLE_PUSH
if you want to use the most recently registered pattern of this category
(if any) before using any pattern of another HANDLE category
Use TT_HANDLE_ROTATE
if you want to use TT_HANDLE.
If no eligible TT_HANDLE_PUSH
patterns are found, use the TT_HANDLE_ROTATE pattern that was least recently used to deliver a message before
using any TT_HANDLE patterns.
Scope — Whether the application is interested in messages about a particular session or file.
Use TT_SESSION
to receive messages from other processes in your session.
Use TT_FILE to
receive messages about the file you have joined.
Use TT_FILE_IN_SESSION
to receive messages for the file you have joined while in this session.
Use TT_BOTH to
receive both messages for the file, the session, or the file and the session
you have joined.
The ToolTalk service compares message attributes to pattern attributes as follows:
The ToolTalk service counts the message attribute as matched if:
No pattern attribute is specified.
The pattern does not name a context slot.
The pattern has an empty context slot.
The fewer pattern attributes you specify, the more messages you become eligible to receive.
If there are multiple values specified for a pattern attribute, one of the values must match the message attribute value. If no value matches, the ToolTalk service will not consider your application as a receiver.
If context slots are contained in the message, the ToolTalk service will not consider your application as a receiver unless:
A value specified in a context slot of a pattern matches the value specified in the message context slot.
When multiple context slots are specified in a message, each context slot value in the message matches a corresponding context slot value in the pattern.
