If you have examined the request and the requested operation cannot be performed by you or any other process with the same ptype as yours, use tt_message_fail to inform the ToolTalk service that the operation cannot be performed. The ToolTalk service will inform the sender that the request failed.
To inform the sender of the reason the request failed, use tt_message_status_set or tt_message_status_string_set before you call tt_message_fail.
The status code you specify with tt_message_status_set must be greater than TT_ERR_LAST.
