When you receive a message, you must check its status. If the status
is TT_WRN_START_MESSAGE, you must
either reply, reject, or fail the message even if the message is a notice,
or issue a tt_message_accept call. Programs started using
the ToolTalk service that receive a status of TT_WRN_START_MESSAGE should check tt_message_uid() and tt_message_gid(). You may
want to fail the request with TT_DESKTOP_EACCES if the UNIX UID and/or GID do not agree with the request. Similarly,
applications already running may want to reject requests with TT_DESKTOP_EACCES if there is UID or GID disagreement.
This will cause serial rejection of the message until either a matching-ID
handler is found, or an autostarted handler fails the request.
