You can tell the ToolTalk service to invoke a callback when a message arrives because a pattern has been matched.
p = tt_pattern_create(); tt_pattern_op_add(p, "EDIT"); ... other pattern attributes tt_pattern_callback_add(p, do_edit_message); tt_pattern_register(p); |
Callbacks are called in reverse order of registration (for example, the most recently added callback is called first).
Figure 11–1 illustrates how the ToolTalk service invokes message and pattern callbacks when tt_message_receive is called to retrieve a new message.
After the ToolTalk service determines the receiver for a message addressed to a handler, it matches the message against any patterns registered by the receiver. (Messages explicitly addressed to handlers are point-to-point messages and do not use pattern matching.)
If the message does not match a pattern, the message is delivered in the normal manner.
If the message is matched to a pattern, any callbacks attached to the pattern are run.
Numeric tags (opnums) can be attached to each signature in a ptype when a static pattern is created. A callback can now be attached to the opnum. When a message is delivered because it matched a static pattern with an opnum, the ToolTalk service checks for any callbacks attached to the opnum and, if any exists, runs them.
