Applications that use the ToolTalk service to communicate usually have something in common – the applications are running in the same session, or they are interested in the same file or data. To register this interest, applications join sessions or files (or both) with the ToolTalk service. This file and session information is used by the ToolTalk service with the message patterns to determine which applications should receive a message.
The scope attributes are restricted to NFS and UFS files systems; file scoping does not work across file systems (for example, a tmpfs file system.)
When a message is scoped to a file, only those applications that have joined the file (and match the remaining attributes) will receive the message. Applications that share interest in a file do not have to be running in the same session.
Table 8–2 describes the types of scopes that use files which you can use to scope messages with patterns.
Table 8–2 Scoping a Message with Patterns to a File|
Type of Scope |
Description |
Scopes to the specified file only. You can
set a session attribute on this type of pattern to provide a file-in-session-like
scoping but a tt_session_join call will not
update the session attribute of a pattern that is scoped to |
Scopes to the union of interest in the file and the session. A pattern with only this scope will match messages that are scoped to the file, or scoped to the session, or scoped to both the file and the session. |
Scopes to the intersection of interest in the file and the session. A pattern with only this scope will only match messages that are scoped to both the file and session. |
To scope to the union of TT_FILE_IN_SESSION and TT_SESSION,
add both scopes to the same pattern, as shown in Example 8–1.
Messages have the same types of file-based scoping mechanisms as patterns. Table 8–3 describes these scopes.
Table 8–3 Scoping Mechanisms for Messages
When a message is scoped to TT_FILE
or TT_BOTH, the ToolTalk client
library checks the database server for all sessions that have clients that
are interested in the file and sends the message to all of the interested
ToolTalk sessions. The ToolTalk sessions then match the messages to the appropriate
clients. The message sender is not required to explicitly
call to tt_file_join.
If a message that is scoped to TT_FILE_IN_SESSION or TT_SESSION contains
a file, the database server is not contacted and the message is sent only
to clients that are scoped to the message's session.
When a message is scoped to a session, only those applications that have connected to that session are considered as potential recipients.
Tt_message m= tt_message_create(); tt_message_scope_set(m, TT_SESSION); tt_message_file_set(m, file); |
The first line creates message. The second line adds scope to message, and the last line adds file attribute that does not affect message scope.
Applications can be very specific about the distribution of a message by specifying TT_FILE_IN_SESSION for the message scope. Only those applications that have joined both the file and the session indicated are considered potential recipients.
Applications can also scope a message to every client that has registered interest in the message's session by specifying TT_SESSION with tt_message_file_set for the message scope. When the message is received by a client whose pattern matches, the receiving client can get the file name by calling tt_message_file.
Tt_message m= tt_message_create(); tt_message_scope_set(m, TT_FILE_IN_SESSION); tt_message_file_set(m, file); |
The first line creates message. The second line adds scope. The third line adds file to message scope.
