Signatures are 4-byte identifiers used to translate platform definitions to ic* form and to differentiate between attributes and other items in the profile format. Set icSignature as appropriate for your operating system.
This icSignature is for the Solaris operating environment. Note the number definitions.
#if defined(sun) || defined(__sun) /* 32-bit Solaris, SunOS */ typedef long icSignature; /* * Number definitions */ /* Unsigned Integer Numbers */ typedef unsigned char icUInt8Number; typedef unsigned short icUInt16Number; typedef unsigned long icUInt32Number; typedef unsigned long icUInt64Number[2]; /* Signed Integer Numbers */ typedef char icInt8Number; typedef short icInt16Number; typedef long icInt32Number; typedef long icInt64Number[2]; /* Fixed Numbers */ typedef long icS15Fixed16Number; typedef unsigned long icU16Fixed16Number; #endif /* 32-bit Solaris, SunOS */ |
The icTagSignature lists the public attributes and sizes in the ICC specification. The attribute icSigProfileSequenceTag is read only and is valid for device link (complete color) profiles only.
typedef enum {
icSigAToB0Tag = 0x41324230L, /* 'A2B0' */
icSigAToB1Tag = 0x41324231L, /* 'A2B1' */
icSigAToB2Tag = 0x41324232L, /* 'A2B2' */
icSigBlueColorantTag = 0x6258595AL, /* 'bXYZ' */
icSigBlueTRCTag = 0x62545243L, /* 'bTRC' */
icSigBToA0Tag = 0x42324130L, /* 'B2A0' */
icSigBToA1Tag = 0x42324131L, /* 'B2A1' */
icSigBToA2Tag = 0x42324132L, /* 'B2A2' */
icSigCalibrationDateTimeTag = 0x63616C74L, /* 'calt' */
icSigCharTargetTag = 0x74617267L, /* 'targ' */
icSigCopyrightTag = 0x63707274L, /* 'cprt' */
icSigDeviceMfgDescTag = 0x646D6E64L, /* 'dmnd' */
icSigDeviceModelDescTag = 0x646D6464L, /* 'dmdd' */
icSigGamutTag = 0x676d7420L, /* 'gmt ' */
icSigGrayTRCTag = 0x6b545243L, /* 'kTRC' */
icSigGreenColorantTag = 0x6758595AL, /* 'gXYZ' */
icSigGreenTRCTag = 0x67545243L, /* 'gTRC' */
icSigLuminanceTag = 0x6C756d69L, /* 'lumi' */
icSigMeasurementTag = 0x6D656173L, /* 'meas' */
icSigMediaBlackPointTag = 0x626B7074L, /* 'bkpt' */
icSigMediaWhitePointTag = 0x77747074L, /* 'wtpt' */
icSigNamedColorTag = 0x6E636f6CL, /* `ncol'
* obsolete, use `ncl2' */
icSigPreview0Tag = 0x70726530L, /* 'pre0' */
icSigPreview1Tag = 0x70726531L, /* 'pre1' */
icSigPreview2Tag = 0x70726532L, /* 'pre2' */
icSigProfileDescriptionTag = 0x64657363L, /* 'desc' */
icSigProfileSequenceDescTag = 0x70736571L, /* 'pseq' */
icSigPs2CRD0Tag = 0x70736430L, /* 'psd0' */
icSigPs2CRD1Tag = 0x70736431L, /* 'psd1' */
icSigPs2CRD2Tag = 0x70736432L, /* 'psd2' */
icSigPs2CRD3Tag = 0x70736433L, /* 'psd3' */
icSigPs2CSATag = 0x70733273L, /* 'ps2s' */
icSigPs2RenderingIntentTag = 0x70733269L, /* 'ps2i' */
icSigRedColorantTag = 0x7258595AL, /* 'rXYZ' */
icSigRedTRCTag = 0x72545243L, /* 'rTRC' */
icSigScreeningDescTag = 0x73637264L, /* 'scrd' */
icSigScreeningTag = 0x7363726EL, /* 'scrn' */
icSigTechnologyTag = 0x74656368L, /* 'tech' */
icSigUcrBgTag = 0x62666420L, /* 'bfd ' */
icSigViewingCondDescTag = 0x76756564L, /* 'vued' */
icSigViewingConditionsTag = 0x76696577L, /* 'view' */
icSigNamedColor2Tag = 0x6E636C32L, /* 'ncl2' */
icSigCrdInfoTag = 0x63726469L, /* 'crdi' */
icMaxEnumTag = 0xFFFFFFFFL /* enum = 4 bytes max */
} icTagSignature;
typedef enum {
icSigCurveType = 0x63757276L, /* 'curv' */
icSigDataType = 0x64617461L, /* 'data' */
icSigDateTimeType = 0x6474696DL, /* 'dtim' */
icSigLut16Type = 0x6d667432L, /* 'mft2' */
icSigLut8Type = 0x6d667431L, /* 'mft1' */
icSigMeasurementType = 0x6D656173L, /* 'meas' */
icSigNamedColorType = 0x6E636f6CL, /* `ncol' , obsolete, use `ncl2' */
icSigProfileSequenceDescType = 0x70736571L, /* 'pseq' */
icSigS15Fixed16ArrayType = 0x73663332L, /* 'sf32' */
icSigScreeningType = 0x7363726EL, /* 'scrn' */
icSigSignatureType = 0x73696720L, /* 'sig ' */
icSigTextType = 0x74657874L, /* 'text' */
icSigTextDescriptionType = 0x64657363L, /* 'desc' */
icSigU16Fixed16ArrayType = 0x75663332L, /* 'uf32' */
icSigUcrBgType = 0x62666420L, /* 'bfd ' */
icSigUInt16ArrayType = 0x75693136L, /* 'ui16' */
icSigUInt32ArrayType = 0x75693332L, /* 'ui32' */
icSigUInt64ArrayType = 0x75693634L, /* 'ui64' */
icSigUInt8ArrayType = 0x75693038L, /* 'ui08' */
icSigViewingConditionsType = 0x76696577L, /* 'view' */
icSigXYZType = 0x58595A20L, /* 'XYZ ' */
icSigXYZArrayType = 0x58595A20L, /* 'XYZ ' */
icSigNamedColor2Type = 0x6E636C32L, /* 'ncl2' */
icMaxEnumType = 0xFFFFFFFFL /* enum = 4 bytes max */
} icTagTypeSignature;
typedef enum {
icSigDigitalCamera = 0x6463616DL, /* 'dcam' */
icSigFilmScanner = 0x6673636EL, /* 'fscn' */
icSigReflectiveScanner = 0x7273636EL, /* 'rscn' */
icSigInkJetPrinter = 0x696A6574L, /* 'ijet' */
icSigThermalWaxPrinter = 0x74776178L, /* 'twax' */
icSigElectrophotographicPrinter = 0x6570686FL, /* 'epho' */
icSigElectrostaticPrinter = 0x65737461L, /* 'esta' */
icSigDyeSublimationPrinter = 0x64737562L, /* 'dsub' */
icSigPhotographicPaperPrinter = 0x7270686FL, /* 'rpho' */
icSigFilmWriter = 0x6670726EL, /* 'fprn' */
icSigVideoMonitor = 0x7669646DL, /* 'vidm' */
icSigVideoCamera = 0x76696463L, /* 'vidc' */
icSigProjectionTelevision = 0x706A7476L, /* 'pjtv' */
icSigCRTDisplay = 0x43525420L, /* 'CRT ' */
icSigPMDisplay = 0x504D4420L, /* 'PMD ' */
icSigAMDisplay = 0x414D4420L, /* 'AMD ' */
icSigPhotoCD = 0x4B504344L, /* 'KPCD' */
icSigPhotoImageSetter = 0x696D6773L, /* 'imgs' */
icSigGravure = 0x67726176L, /* 'grav' */
icSigOffsetLithography = 0x6F666673L, /* 'offs' */
icSigSilkscreen = 0x73696C6BL, /* 'silk' */
icSigFlexography = 0x666C6578L, /* 'flex' */
icMaxEnumTechnology = 0xFFFFFFFFL /* enum = 4 bytes max */
} icTechnologySignature;
