typedef struct {
icStandardObserver stdObserver; /* Standard observer */
icXYZNumber backing; /* XYZ for backing material */
icMeasurementGeometry geometry; /* Measurement geometry */
icMeasurementFlare flare; /* Measurement flare */
icIlluminant illuminant; /* Illuminant */
} icMeasurement;
Each field in icMeasurement is an enumerated type. For details on each field, see the following:
icStandardObserver - See "icStandardObserver".
icXYZNumber- See "icCurve".
icMeasurementGeometry - See "icMeasurementGeometry".
icIlluminant - See "icIlluminant".
icNamedColor is obsolete. Use icNamedColor2.
